-   Lifting Tech (https://blazerforum.com/forum/lifting-tech-44/)
-   -   Why dont they make a lift... (https://blazerforum.com/forum/lifting-tech-44/why-dont-they-make-lift-18962/)
98BlazerLT4x4 03-27-2008 10:42 PM
That has longer top and bottom control arms and longer axle shafts, so tweaking the torsion bars wouldn't kill the cv angles and you would get a wider stance??
navyblue_sk8er 03-27-2008 11:15 PM
RE: Why dont they make a lift...
Isn't that what they did with the ZR2?
a_tack 03-27-2008 11:24 PM
ORIGINAL: navyblue_sk8er
haha... kind of...
the 5-6 inch lift doesnt kill your tb's.... it lowers them along with the front diff..
98BlazerLT4x4 03-27-2008 11:59 PM
Why would you lower your diff when what I said earlier can do the same thing but you can keep your diff outta harms way?
a_tack 03-28-2008 12:09 AM
i didnt say you need to... just said thats the only way your gonna retain any stock front end angles...lol I agree they should make more truck friendly lifts
WolfPack 03-28-2008 10:29 AM
I wish they had a long arm kit as well. Jeeps get all the fun stuff...I just want better travel with less spine misalignment:D
Jigg 03-28-2008 10:42 AM
ORIGINAL: 98BlazerLT4x4
Because cranking the torsion bars makes the ride stiffer. Cranking them past the allowable 1.5" that you can stock (which is where the cv and ball joint angle problems come into effect), would give you a HORRIBLE ride and nobody would buy the kit.
98BlazerLT4x4 03-28-2008 02:36 PM
Maybe a kit could include upper and lower control arms, axles, and torsion bars designed to be lifted. Seems that would be better than a $2000 kit that just drops the suspension.
Jigg 03-28-2008 02:57 PM
It'd be a lot more than $2000...
WolfPack 03-28-2008 06:49 PM
Haha yea...might as well buy a new vehicle for that. You're talking an entirely different suspension system...
