will 31's work ?
Old Dec 12, 2011 | 11:15 PM
xgiovannix12's Avatar
a 1.5 inch tbar crank 2 inch shackle lift would work with 31s with stock s10 rims
I had to grind my plastic fender flares about an inch but it all worked out well
if you have sagging tbars (weak) the 31s will rub you need to make sure your getting an inch 1/2 lift
also you might wanna swap out your shocks later on since stockers are shorter since you lifted the truck
I still didn't replace them yet but mine are going so imma buy the ones made for 2 inch lift in the future
Old Dec 13, 2011 | 09:14 AM
89DropTop's Avatar
89DropTop is on a distinguished road
Originally Posted by Rottidog
not sure I know what that means
I'm not sure I want to know what that means lol
lmao just bout my truck. haha nothin awkward. but i have a blown head gasket and dont have the time or money to fix it. and hoping the block aint cracked so i need to get rid of it. but not for free. so im either partin it out or selling it to someone that wants a project truck..
Old Dec 13, 2011 | 01:10 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
at least I wasn't the only one confused by that lmao
Old Dec 13, 2011 | 03:49 PM
89DropTop's Avatar
hahaha bite me! :P lol
Old Dec 14, 2011 | 11:50 PM
89Recon's Avatar
If I wanted to run 33's what gearing would I have to go with? I was thinking 4.10 or 4.56 I can't remember the exact number. As for the lift I would do 2" t bar crank , 2" rear lift shackles, and a 3" body lift so that should be more than enough clearance just need to know what gears to use.
Old Dec 14, 2011 | 11:54 PM
i think 4.10s are good for 33s and tbars can only be cranked 1.5 inches
Unless you buy rough countrys new 2.5 inch suspension lift
Old Dec 15, 2011 | 12:01 AM
89Recon's Avatar
Sweet, so I am think that is going to be my final plan I have been changing my mind so many times but I think I am finally decided 1.5" t bar crank, 2" rear lift shackles, 3" body lift, 4.10 gears, and 33" tires on my stock wheels ....... how do you all think it will turn out? you will have to wait until I get my $$$ and check out my build thread lol
Old Dec 15, 2011 | 12:04 AM
I never tryed to put 33s
I got 31s with a 1.5 tbar crank with 2 inch shackles
Ive seen people run 33s on 3.73s also
Old Dec 15, 2011 | 12:07 AM
89Recon's Avatar
So gio here are some Yukon 4.11's will these work ?
High performance Yukon Ring & Pinion gear set for GM 7.5" in a 4.11 ratio - YG GM7.5-411T
almost forgot to ask is there any kind of install kit I need to buy along with that?
Old Dec 15, 2011 | 12:15 AM
I never changed gear ratios in rear ends before so i couldn't tell you
