zone body lift or PA, 99 blazer
Old Mar 18, 2014 | 02:32 PM
rekker94's Avatar
rekker94 is on a distinguished road
Default zone body lift or PA, 99 blazer
I plan on putting a 2 inch body lift on my 99 4 door blazer. I've been going back and forth between the Performance Accessories body lift and the Zone body lift the shop by me is selling. Which do you guys recommend? Thanks!
Old Mar 18, 2014 | 03:54 PM
newguy's Avatar
They`re probably basically the same. never heard of zone only PA
Old Mar 19, 2014 | 11:49 PM
95blazerlt's Avatar
95blazerlt is on a distinguished road
Zone Offroad 2" Body Lift Kit 98-04 S-Series Blazer/Jimmy C9211
http://performanceaccessories.com/ve...ml#/years-2000
Looks to be almost identical to the pa kit, but it looks like its missing the fuel filler neck extension pipe the pa kit comes with.
Old Mar 20, 2014 | 07:26 AM
okiedoak20's Avatar
I was checking out Zone body lift when I was looking to do mine...
Not busting on any one product, butthe zone kit seems to have
Some extra parts that allowed for the re attachment of the
Front tow hooks that the PA kit lacked...other wisethey seem to be
The same....the PA kit was slightly less $$ so I went with those guys.
Old Mar 20, 2014 | 10:21 AM
rekker94's Avatar
Thanks for your help! I think I'm going to go with the PA Kit!
Old Mar 21, 2014 | 03:26 PM
Kevin Heald's Avatar
Kevin Heald is on a distinguished road
I put the Zone kit on my 2004 4dr. Everything worked out fine. I did have to trim the bottom of the rear bumper where it was hitting the frame. I did not need to use the gas tank filler extension hose, the stock one was long enough to reach. I also had to trim out the rear frame in areas to get the spare tire winch to line up with the stock hole in the rear bumper. When you do the body lift you might want to replace the body bushings as well. I put Prothane bushings in (
http://www.amazon.com/dp/B003AVV762/ref=pe_385040_30332190_TE_M3T1_ST1_dp_1 http://www.amazon.com/dp/B003AVV762/ref=pe_385040_30332190_TE_M3T1_ST1_dp_1
You can check out some pics here:
Blazer Forum - Chevy Blazer Forums - Kevin Heald's Album: Garage - 2004 Blazer LS 4Dr 4x4
Old Mar 21, 2014 | 04:30 PM
rekker94's Avatar
I might do that then! The shop by me sells the zone lift but I can get the pa for cheaper than the zone so I'm going back and forth between the two!
Old Mar 21, 2014 | 05:14 PM
cleburne red's Avatar
Am I the only one that saw "zone", and thought it was some cool slang for "Autozone?"
rob_bellamy
Oct 28, 2010 03:32 PM
okiedoak20
Lifting Tech
Jun 29, 2010 09:38 AM
coasterkid
May 7, 2010 01:22 PM
Chuck_X2
Feb 15, 2010 07:32 PM
Aquahallic
Sep 1, 2006 10:17 AM
