1996 blazer turn signal issue
i have a 96 blazer . the turn signals wont work . the hazzards work but the turn signals wont . i have replaced the flasher . i think it could be the switch but all in the same im thinking it could be something else . the windshield wipers work and the curse control works as well just the turn signals dont work . i know all the bulbs are good because they flash with the hazzards
It's a stab in the dark, but what about the fuse?
the fuse is good and has been replaced had a short fixed the short lol . the flasher has been replaced as well . the rear will flash as long as i manually do it and the lights are on or the break is being pressed , but i dont get anything from the front lights even though the bulbs and flasher are good . also the hazard lights are good and in working order so any ideas ??? lol i really hope its not the switch witch i think it is but i wanted to pick everyones ear about it before i try to screw with the pain in the ass of replacing the switch
thanks for the shot in the dark Diaita i just forgot to mention that the fuse is good is all sorry for that man
Do the backup lights work? Are there any other electrical items that don't work?
I'm thinking it's the fuse (turn/backup #16), the flasher relay, or the wiring in between. |
i remember the hazard switch went out on my blazer once none of the rear lights worked don't remember the part number though, it cost about 25 at the chevy dealer
like this one http://www.ebay.com/itm/7A4-MULTI-TU...item4ac43352d7 |
my hazards work along with all my rear end lights even the back up lights work the only lights not working is my turn signals . i know all the bulbs are good as well ive either pulled them out or seen them light up . i have replaced the flasher as well
Multifunction switch?
thats prolly the issue and i believe i have another short now because my back up lights wont go out now when the lights are on btw all the fuses are good so its not a fuse and the hasard lights do not work now after this rain
i fired the thing up earlier i turned on the lights and the battary guage wasnt charging untill i reved it up and when the lights are on it charges right at 14 volts . and just so everyone knows my blazer has been wrecked and has a buckled hood no girll and a bent bumper and fender there was a short by the break spitter for the abs on the driver side on a baby blue wire i spiced into it and replaced a section of it and havent had an issue till today . the weather was wet and nasty . btw i know i need to at least get a new hood for the truck it would help things out a lot i know lol
