2 problems; Brake light and 4wd issues
Old Nov 17, 2011 | 06:14 PM
wireman's Avatar
wireman is on a distinguished road
Default 2 problems; Brake light and 4wd issues
Hello all, needing some information on two issues:
1st issue: Brake light flashes on and stays on when I turn the wheels to the left, and goes off when turning back, the brakes are working fine with no problems(except e-brake does not work very well).
2nd issue: 4wd does not work-no lights on switch or no sound when I push the buttons.
These things just began to happen "all of a sudden" with no prior warnings, or is this the warning for some other issue....any info will be greatly appreciated.
Thanks in advance.
Old Nov 17, 2011 | 06:44 PM
pettyfog's Avatar
I'm gonna do a Carnac and guess it's a 2002
Brake light:
Do your hazard lights and turn signal work properly? Pull HAZ lamp fuse in underhood Fuseblock and see if it still does it
All other brake sw functions? Incl Park detent release and cruise control.
__________________________________________________ _________________________________
4wd /tccm
Do your courtesy lamps work?
Also check underhood ATC fuse
Old Nov 17, 2011 | 07:16 PM
Camaro1's Avatar
Camaro1 is on a distinguished road
for your 4wd, check your fuse first due to the lack of lights and power you have, next reset the TCCM pull the fuse for 2 minutes turn the key on and off 5 times...now i do not mean turn to the run position im talking about turning it to the click before that. then if thatdoesnt work i want you to Go find the thread about Jumping the Pins with a paper clip and last but not least if it is the fuse do that for not checking that first.
Old Nov 18, 2011 | 04:59 PM
wireman's Avatar
Brake light:
4wd /tccm
Fuses are good....also cruise control isnt working also...
Old Nov 18, 2011 | 05:34 PM
pettyfog's Avatar
Now pull the haz lmp fuse underhood, drive it and see if it still does it.
If it does, touch-wiggle the harness into stop switch where brake master cyl shaft intersects brake pedal arm.
steve72
Sep 1, 2014 11:41 PM
foanc
Dec 12, 2012 02:09 AM
tripovermyego
Apr 12, 2012 04:09 PM
Jonboy
Mar 12, 2012 07:08 PM
