-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   2000 Blazer, A/C doesn't work (https://blazerforum.com/forum/lighting-electrical-52/2000-blazer-c-doesnt-work-78452/)
dagunrpuppet Apr 7, 2013 01:05 PM
I recently did the heater core on my 2000 Blazer and now no matter what I select on the a/c-heater selector switch I only have 1 temperature, hell. That was fine during winter but now it is getting nice out and the wife needs the a/c. When I select A/C I have noticed it is not cycling the compressor. I have tried checking signal out of the back of the head unit and the wire I think controls the A/C doesn't show any power leaving the unit. Not sure if this is correct though, just my assumption. However, it worked before I did the heater core and now it does not. Any and all help would be greatly appreciated.
WitchingHour Apr 7, 2013 02:05 PM
On the back of the accumulator is your pressure switch. Disconnect it, and take a small piece of wire to jump between the two terminals. If your compressor doesn't engage, it probably means a bad pressure switch. I'll go out and take some photos for you.
WitchingHour Apr 7, 2013 02:21 PM
This is your accumulator. If you ever do anything in which you have to open up the AC system and allow entry of ambient air, you should always replace this, as the accumulator contains a desiccant which will become fully saturated within five minutes of exposure. The desiccant ensures that only vapor - no liquid - travels to the AC compressor, and this is a very vital component.
https://farm9.staticflickr.com/8392/...486b6771_o.jpg
This is the wire to the pressure switch. Disconnect this.
https://farm9.staticflickr.com/8405/...59ab5557_o.jpg
Run a piece of jumper wire between these two contact points (with the engine running, of course). The compressor should engage and will stay engaged until the jumper wire is removed. If you have a manifold gauge set attached, you'll see a steady increase in system pressure.
https://farm9.staticflickr.com/8099/...ef544673_o.jpg
If the compressor doesn't engage, consider replacing the pressure switch. The part is less than $20.
armykyle1 Apr 7, 2013 04:38 PM
Nice tip. I have a similar issue but I think mine is a lot deeper. Can't can't change vent section.
WitchingHour Apr 7, 2013 05:43 PM
Sounds like one of your doors is jammed, or a cable broke. You can access the HVAC ductwork easily enough... I haven't done this with mine, so I'm not yet sure where the precise locations of the doors are.
bwallace541 Jul 24, 2019 05:15 PM
Thanks
So in my searching I did come across this. I jumped it with a paper clip and nothing happened.
so even tho i can’t get the ac button to come on it should still kick the compressor on when I jump the switch. I just ran out and tried again but it didn’t work
