2000 Jimmy Back Up Light Problem
Hey everyone. I have a 2000 Jimmy 2D 4.3L with an auto trans and im having a reverse light problem. I have changed the Switch on the side of the trans already. Is there another switch on the column? I have checked all the fuses. I just cant figure it out, when i changed the switch the first time it worked for awhile and stopped. So i changed it again but nothing, I changed another one out to be sure i didnt get a bad one. Any help would be great.
Thanks Brian |
I have to fiddle with mine to get reverse lights to work, I have to go to N then to R and the lights work. I would also like to know if there is a switch in the column.
thnaks |
Mine will not even do anything is i move the shifter around. I tried that the other day
