2001 Blazer. Electrical problems
Old Feb 2, 2016 | 04:23 PM
Zankou's Avatar
Zankou is on a distinguished road
Default 2001 Blazer. Electrical problems
I have had these issues for a while but I wanna fix them up since Ive decided to keep this truck and I wanna take care of it.
1- The electric door lock button on the passanger or drivers side does not function at all. When I turn the car on and off the doors do lock and unlock themselves but the not with the switch.
2- The rear hatch button does not work from the outside or the inside. When I press it nothing happens.
3- The mirror controllers dont work on both sides.
I recently got a multimeter but I am not sure what readings to look for when checking the wires. I was hoping someone could help me diagnose and see if these problems are caused by the switches or the wiring.. or something else.
Thanks!
Old Feb 3, 2016 | 07:34 PM
rxjimmy's Avatar
rxjimmy is on a distinguished road
1 and 3 could be tarnished or dried grease on the switch contacts in the switches themselves. They can be taken apart, cleaned and re-lubed with dielectric grease. For #2, the rear switch in the hatch is the same. I had the same problems. All cleared up with the clean and grease process. Been going good for the past year. Possibly, the inside hatch switch could be a similar problem. I have not had to clean that one.
It is a bit of work to get to the rear hatch switch but not any worse than having to replace them.
Old Feb 3, 2016 | 11:48 PM
burned's Avatar
burned is on a distinguished road
When you use a meter to check, set it to resistance or continuity. You are looking for breaks in the wiring or a switch not making a contact. Resistance should be low or continuity should beep if its a good circuit. Electrical contact cleaner is good for cleaning out the carbon, dirt...etc inside a switch.
Old Feb 3, 2016 | 11:49 PM
Zankou's Avatar
I actually fixed 1 and 3 by replacing the 3 amp fuse under the hood...
For #2, is there a fuse for that? If so whats the name of it? I am thinking it might be the because of a blown fuse? What are the chances of the switch contacts going out both on the back and for the inside switch at the same time?
JoSHN
Sep 14, 2012 04:56 PM
pwg212
Oct 21, 2010 06:22 PM
gbdane
Aug 20, 2010 06:49 PM
nezoic
Jan 23, 2010 07:55 AM
89LX
Mar 7, 2009 12:57 PM
