71 K5 Dome Light
Does anyone have any good solutions for potentially a battery powered dome light? The occasionally remove the top so it really needs to be battery powered.
Do you have a roll bar in yours? If so they make Velcro battery powered roll bar dome lights.
https://www.walmart.com/ip/Rampage-7...&wl13=&veh=sem If not and you want a inexpensive solution, go to walmart and pick up some press on press off type lights and command strip them to the roof. https://www.walmart.com/ip/Fulcrum-L...-Pack/15048592 |
Originally Posted by ChuckNTruck
(Post 678434)
https://www.walmart.com/ip/Rampage-7...&wl13=&veh=sem If not and you want a inexpensive solution, go to walmart and pick up some press on press off type lights and command strip them to the roof. https://www.walmart.com/ip/Fulcrum-L...-Pack/15048592 Installing one next week so that might work. Also just found this which seems to look fine. https://www.extremeterrain.com/omix-...k-1243001.html |
