-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   87 k5 electrical issue (https://blazerforum.com/forum/lighting-electrical-52/87-k5-electrical-issue-87086/)
87k5Beast 09-03-2014 08:44 AM
I was driving it the other day and noticed I had 8-10 volts. I shut it off to visit a friend and go to leave and try to start it and it cranks slow for a second then here a pop and saw a small amount of smoke come out of the passenger side under the hood. Now there is no power to the dash, power locks, power windows and the starter won't engage. I have headlights and dome light. What could be the problem?
Maggz 09-03-2014 02:53 PM
Blown fuseable link on the master wiring harness could be an issue. The low voltage could be caused by a bad voltage regulator (which is built into your alternator). The fusable links are typically within the first 3 feet of your wiring harness which comes off of the battery and might connect to a junction block and separate from there. It might be on your inner fender mounted somewhere up top. Hope this helps you.
