96 blazer 4wd switch no lights
Old Aug 25, 2014 | 04:56 PM
mlowrey84's Avatar
mlowrey84 is on a distinguished road
Default 96 blazer 4wd switch no lights
Replaced my 4wd select switch no lights on, all fuses inside are good. Also stuck in 4wd low. Driving me crazy I need some help
Old Aug 25, 2014 | 06:06 PM
Maggz's Avatar
Maggz is on a distinguished road
I am finding a similar issue but more wide spread for my part, I thought it might have been related to the key switch but all output tested good on my end. If this is the only issue you are having tho your issue is probably not the same as mine. Have you checked and cleaned the harness to the 4wd control box, it should be mounted under dash somewhere above the right side of the steering wheel mount. I hope this helps you.
Old Aug 25, 2014 | 06:53 PM
Jeklund's Avatar
Jeklund is on a distinguished road
Could be a vacuum issue or something to do with the actuator. Check your vacuum lines to make sure there are no leaks.
I found that the climate control vent selector uses the vacuum so if you are unable to change the vent with your climate control that could indicate a vacuum issue that could be affecting your 4wd as well.
If you are unable to find an issue with the vacuum then I would move to the actuator and see if it's seized up. On my old Jimmy and my current blazer I've had to replace them.
Old Aug 26, 2014 | 04:42 PM
mlowrey84's Avatar
well vac actuator under battery tray is good. someone said something about ATC fuse would make lights not work. if I knew where that was I would check it out. lights haven't worked since I have owned it and it is stuck in 4 lo since I have had it also. but would vac switch on the transfer case not make the lights work?
Old Aug 26, 2014 | 04:47 PM
mlowrey84's Avatar
but I saw a diagram on vac system that goes from actuator under battery tray it looks like its supposed to go straight to the transfer case but mine Ts off to a vac switch ill have to post a pic later tonight
Old Aug 27, 2014 | 07:34 AM
squeekies blazer's Avatar
squeekies blazer is on a distinguished road
Default 4x4 nothing works
when i press switch to change from 2 high to 4 high or low nothing happens no flickerin g or flashing lights no noise from anywhere i need help as i havnt got a clue what to do
Old Aug 27, 2014 | 09:35 PM
mlowrey84's Avatar
everyone keeps telling me its my transfer case motor and told me to take off motor and just run around with it off til can replace it and it wont hurt nothing
BearingEater
Jun 17, 2011 03:16 PM
edavison
Dec 20, 2010 09:55 PM
hambone8
Apr 14, 2010 01:32 PM
chrisblaze
Dec 6, 2009 12:27 AM
LYK2ROC
Dec 5, 2008 07:08 PM
