-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   96 s10 blazer headlight removalmoval and replacement (https://blazerforum.com/forum/lighting-electrical-52/96-s10-blazer-headlight-removalmoval-replacement-76874/)
evfeez25 01-29-2013 04:41 PM
2 Attachment(s)
Ok so i have attached a picture of the headlight assembly i have in my 96 blazer. I would like to replace them and upgrade the bulbs so they are brighter and i can see better but i cant seem to figure out how to get them out. I am also wondering if there are sealed beam lights inside the assembly. Im asking this because every time search for replacement healights it comes up with 4x6 sealed beam replacements but it doesnt look like thats what they are. any help would be much appreciated.
richphotos 01-29-2013 05:09 PM
Looks like you have the composite headlights, open up your hood, and look behind the headlight, should be able to remove the bulb, and find out what kind it is, I am not exactly sure what bulb yours uses.
Diaita 01-29-2013 05:12 PM
your hi-beam bulb is a 9005, low-beam is a 9006. They're real common
evfeez25 01-29-2013 05:25 PM
well heres the problem with it i cant seem to get to the back of the headlight because of the mounting bracket and on the front of the headlight there are 4 clips which seem to hold the front lense on
evfeez25 01-29-2013 05:35 PM
the only way i can see to get it out is to completely unsrew the adjusters
richphotos 01-29-2013 05:35 PM
*added link for removal in next post*
richphotos 01-29-2013 05:37 PM
Here you go
http://www.bodyshopzone.com/archives...blazer_hl.html
evfeez25 01-29-2013 05:37 PM
i can try that and then prying the front lens off to get to the bulbs it seemed to be sealed pretty tight anything i should do when i put it back on or will it just seal back up
richphotos 01-29-2013 05:43 PM
No, dont do that, Look at the link I just put in here.
evfeez25 01-29-2013 06:25 PM
Replace Headlight Bulbs On A 1996 Chevy Blazer, S10, GMC Jimmy, Sonoma
ok so if you are having trouble as i did check out this link it was very helpful shows you exactly what you have to do. Thanks if you tried to help but here's the correct way
