97 Blazer electrical problems
Old Apr 7, 2011 | 05:18 PM
ezh10111's Avatar
ezh10111 is on a distinguished road
Default 97 Blazer electrical problems
I have a 97 blazer that has a bad fuel gauge, even after I replaced the fuel pump. Also my power windows work even if the switch is not on.Last my a/c is also able to turn on even if the switch is not on.I anyone could help out I would appreciate it.
Old Apr 19, 2011 | 12:18 PM
Concerning the fuel gauge, a continuity test on the wire from the sending unit in the tank to the PCM is in order. While not 100% applicable to your truck, the 98+ Fuel Gauge Diagnosis thread may give you some ideas on what else to check.
What switch are you talking about with the windows?
The A/C compressor can come on when one of the windshield defrost modes is selected. The A/C system will remove moisture from the air which will decrease the amount of time it takes to remove the condensation from the windshield.
Old Apr 20, 2011 | 01:56 PM
ezh10111's Avatar
Well my power windows are not suppose to work unless the switch is on, but they do. As for the A/C i can turn on the blower without having the switch on, which is not suppose to be able to.
Old Apr 20, 2011 | 02:00 PM
One more time...
Are you talking about the ignition switch?
I find that the more I assume, the more people creatively name things that lead to an incorrect assumption. So I try not to assume and just ask.
Old Apr 20, 2011 | 10:10 PM
ezh10111's Avatar
yes the ignition switch
1993 S10 BLAZER 4X4 CPI
Sep 16, 2012 11:28 AM
JoSHN
Sep 14, 2012 04:56 PM
tonytime
Mar 27, 2010 11:04 PM
89LX
Mar 7, 2009 12:57 PM
joe
Apr 19, 2006 05:33 PM
