-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   97 blazer start problem (https://blazerforum.com/forum/lighting-electrical-52/97-blazer-start-problem-62345/)
neonguy1 Aug 21, 2011 02:07 PM
blazer won't crank replaced starter, ignition switch thinking maybe nss. can't find location have a haynes manual nothing. any help
xgiovannix12 Aug 22, 2011 12:27 AM
Did you check the crank fuse ? also i think 2nd gen blazers have starter relays
neonguy1 Aug 27, 2011 03:59 PM
thanks I'll check relays replaced nss still no start
swartlkk Aug 27, 2011 05:19 PM
You have to walk through the system. There isn't a lot of points to test at.
A schematic applicable to your truck can be found in THIS THREAD.
neonguy1 Sep 2, 2011 05:02 PM
thanks guys found 1 loose ground tighten still nothing replaced relay nothing. I can jump across relay and & start. the guy at auto parts store said maybe its the key switch. I dont think so any Ideas. everything works but start thanks again for your help
