97 s10 disable door alarm
Hey I have a 1997 Chevrolet Blazer S10 4-door. I constantly work with the door open and that buzzer always stays on. Id like to disable it somehow. I tried tape over the push button but that doesn't hold it in. I thought it would be possible to pull out that button switch and connect two wires together or something to make it always pushed in or something like that but I have absolutely no idea. So what would my options be for disabling it?
Thanks in advance Edit: All I basically want is the sound to stop for it. I just realized that by making that switch stay shut, the light wont come on when you open the door i believe. So Id like to keep that but id like to stop the annoying buzzer if possible. |
The door switches work by completing the ground circuit. Removing the switch, disconnecting the wiring, and taping off the connector should remove that switch from the circuit.
This damn car won't stop beeping no matter what I do.
How to get this damn car to stop beeping. Once the key goes into the ignition it starts this rechid beeping sound non stop until the car is shut off again. I hate it. Any ideas how to get it to be quite
Originally Posted by swartlkk
(Post 524387)
