98 Blazer - Flasher Issue
I have a 98 Blazer LS where the sound (clicking) for the turn signal flashers is always on unless I have the brake applied. I have tried replacing the flasher in the dash behind the glove compartment and the issue remained.
Any advice would be greatly appreciated. Thanks!
-EDIT- My hazards work normally
flasher issue
I am having the same issue. Replace turn signal assembly. You could start with the cheapest thing to replace and that would be the hazard light assembly. I'm betting the turn signal assembly.
Sorta sad...
How did the OP get lost? That's a really easy problem to answer. I would have because I had the same problem less than 2 months earlier.
Turn signal {possibly just hazard} switch.
4x4blazerguy
03-15-2010 07:57 PM
guyd_15
07-03-2009 04:21 PM
kbreck
07-10-2008 07:23 PM
