2001 zr2 turn signal brake light problem
]I have a 2001 ZR2 and today my brake light and turn signal on the pass side stopped working. The front flashes fast but still works. I checked both bulbs and they are fine. I'm hoping it's not the multifunction switch. Any ideas? The other side and the 3rd brake light work perfect. I was told it might be the brake light switch.
any help would be appreciated
[QUOTE=Tom Zambori;676549]I have a 2001 ZR2 and today my brake light and turn signal on the pass side stopped working. The front flashes fast but still works. I checked both bulbs and they are fine. I'm hoping it's not the multifunction switch. Any ideas? The other side and the 3rd brake light work perfect. I was told it might be the brake light switch.
I would start with getting some new bulbs (even if you think they look "good" does not mean they are" If that does not work, I would start probing around with a digital multi-meter at the socket to make sure you are getting power and ground on the socket/s
New bulbs. Did all the basic stuff. I was him a replace the brake light switch and see if that dies the problem. I do t think it would be the multifunction since all the other signals work. Just not the rear pass side. Same with hazards. All work except that one.
jasondis
04-05-2014 04:54 PM
drummerdude
12-17-2009 09:55 PM
tim_dean
03-30-2008 09:02 AM
Jimonawing
11-16-2007 02:38 AM
