98 blazer ls with no back up lights
Old Jun 7, 2013 | 04:42 PM
nbguide's Avatar
nbguide is on a distinguished road
Default 98 blazer ls with no back up lights
No back up lights. I tried going slow through the gears to see if they'll light up and nothing. Is there a fuse for just the back up lights? Is there a connector or sensor by the transmission? I've seen screw in sensors for manual transmissions but can find nothing for automatic transmission? Any help would be appreciated.
Old Jun 7, 2013 | 06:15 PM
Key ON, engine OFF, transmission in reverse: In the underhood fuse panel, check both terminals of "B/U LP 25 amp fuse" and both terminals of "VEH B/U 15 amp fuse". Do not remove the fuses when testing, probe the two visible terminals on the top of each fuse. They should each show battery voltage.
Key ON, engine OFF, transmission in reverse: At the B/U lamp sockets, remove the bulbs: One terminal should show battery voltage, and the other should show less than 5 ohms resistance to ground.
Post your results.
Old Jun 7, 2013 | 10:57 PM
richphotos's Avatar
cap, you are the killer with info man... always blows me away.
Old Jun 8, 2013 | 09:36 AM
nbguide's Avatar
Thanks Captain. I'll do those things when this rain ends. Appreciate it.
Old Jun 8, 2013 | 09:56 AM
rexazz2's Avatar
Post your results.
remember the good old days when you would just replace the switch
Old Jun 8, 2013 | 12:32 PM
nbguide's Avatar
I checked the fuses and there is no voltage to the fuses. Where's the problem?
Old Jun 8, 2013 | 05:39 PM
If no back up lights is the ONLY problem you're having, the cause is inside the underhood fuse panel.
The easiest way to repair it is to run a jumper wire outside the fuse panel to supply the circuit with voltage. You'll need two fuse taps, two female 1/4" spade terminals, and a piece of 14ga wire:
Step one: Remove the "B/U LP" 25 amp fuse. The tap must be connected to the un-fused side of the "B/U LP" fuse socket. To determine which socket is un-fused: Key ON, engine OFF, transmission in reverse: run a temporary jumper wire from battery positive to each B/U LP fuse socket. One socket will light the B/U lights, and one socket will do nothing. The fuse tap must go to the socket that does nothing. Install the B/U LP fuse and fuse tap.
Step two: Locate the IGN E fuse and remove it. Ignition in the RUN position, probe both sockets of the IGN E fuse. One will have battery voltage, (one will show zero volts). Insert the other fuse tap in the socket that shows battery voltage, reinstall the IGN E fuse. Make up a 14 gauge jumper wire with a female 1/4" spade connector on each end. Connect the two fuse taps. Done.
Attached Thumbnails 98 blazer ls with no back up lights-fusetap_zpse72139da.jpg
Old Jun 8, 2013 | 06:05 PM
nbguide's Avatar
Thank you!! I will try this and would never have gotten there on my own. Thanks again.
Old Jun 8, 2013 | 06:12 PM
Piece of cake, no problem Let us know how it goes.
Old Jun 10, 2013 | 05:59 PM
nbguide's Avatar
Back up lights are working again. Thanks. I also added some Walmart platinum burner 2.5" round lights to the back bumper for extra light out in the woods. Thanks again Captain.
