absence of trouble codes
Greetings; I'm going to try my best to describe wut is going on with my '99 s10 blazer 4x4 ( so please bare with me).
since I got the rig , there has been several times in which it has had a problem or issue, ( misfire, broken speed sensor, not running good at all going up hill , etc. So while trying to get things fixed, I plug in my OBD2 code reader in, & guess what!: no stored codes, no recent codes, nothing. not only has ther never been any trouble codes, the S.E.S. light has nvr came on to notify me of a problem. & the S.E.S. light does work, it lights up when I turn the key to start the engine. I don't know if it matters, but, when I was driving my '98 s10 blazer 4x4, that S.E.S. light would light up when there was issues with emissions, transmission trouble, etc. so my question is this: why isn't my S.E.S. light lighting up to inform me of a problem? |
Originally Posted by StarScreamin
(Post 690795)
Originally Posted by Lesmyer
(Post 690853)
Does the SES light work with the key on/engine off?
(Post 690867)
Yes, after turning the ignition to on ( not to start) it stays on until after I start the rig
enhanced trouble codes
So after being able to access the enhanced GM codes in this '99 s10 blazer 4x4, it came up with 5 codes:
P0605:control module programming U1026: loss of class 2 communication with ATC U1042: Lost communications with brake/ traction control system U1192: loss of passlock/ EVO class 2 communication U1193loss of VIM class 2 communications. Now, could someone please explain what these mean? thank you ahead of time for all your help. |
Codes list
There is list of codes at this site. All of those communication codes should clear if you fix the P code. Sounds like you have a bad communications module. Maybe the computer needs to be reflashed??
| All times are GMT -5. The time now is 08:58 AM. |
