ad244 wiring 1st gen
As far as I understand, I will need to wire a new connector in place of my old 2 wire CS130 for this swap. What wires will I be wiring where in the new connector?
Bump. I pulled the alt and connector from the junkyard, which wires am I splicing to the old harness?
Sorry I can't find it, but it's either on here, or s10forum that someone showed which wires. You might have better luck searching than I did right now.
Figured it out, the two wires in the center are used. Easy enough
I know when I did my swap on my first gen I got a wiring kit for it that included a resistor to keep the function of the dummy light on the dash. I have searched and searched and cant find that damn harness.
Here is a link to the adapter harness with the resistor included
Painless Performance Products 30705: Alternator Pigtail CS 130D Style GM Alternator (Internal Fan) | JEGS |
