-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   any 1 know the wattage for the dome lights under the dash ? (https://blazerforum.com/forum/lighting-electrical-52/any-1-know-wattage-dome-lights-under-dash-64090/)
xgiovannix12 10-16-2011 09:22 PM
i have regular bulbs in there and they get 2 hot i really think im overloading the system
I think there 27 watt bulbs there the ones you can use for your reverse lights
also is there a set of white leds for them ?
Thogert 10-17-2011 12:26 AM
Superbrightleds.com has just about every bulb for cars, and most in lots of colors. They also have a vehicle bulb finder that can tell you which ones you need. On mine they are the t10's, but it may be different on the first gens.
xgiovannix12 10-17-2011 12:48 AM
thanks thogert but i think imma put reg bulbs for now
I needa see what kind go there cause the ones i have they heat up to much
Im afraid im over loading the system
Thogert 10-17-2011 12:57 AM
Is it wedge based?
Edit: I mentioned that they may be T10's. The corner lights on your dads s10 have T10's. you could see if those fit than those are the ones you need.
xgiovannix12 10-17-2011 05:46 PM
No they are like the bulbs you put in your reverse sockets just the ones i put are 27 watts
I think they are the ones causing my radio horn dome light fuse to get hot
Mike98Blazer 10-17-2011 08:39 PM
replace them with lower wattage bulbs?
I'd say 27 watts is definately too much for courtesy lighting, considering most headlights are only 55 watts lol
xgiovannix12 10-17-2011 08:55 PM
yea :icon_no: it was so nice to have them they were so bright
pettyfog 10-17-2011 09:04 PM
I GUESS!
Automotive Bulb Visual Finder
is a dome light
is plenty for a footwell light
xgiovannix12 10-17-2011 09:18 PM
there arent t10s or t15s they look like 1157s
Magmotor 10-18-2011 01:56 AM
Here is a complete list of every bulb in a '93 and replacement needed:
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Here is the link to Auto Zone's "step/courtesy" light (12 watts) that matches what is in my service manual for this application:
Sylvania/Trunk / Cargo Light Bulb (1003LL) | AutoZone.com
hope this helps a little.......
