-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Audi/BMW side marker MOD (https://blazerforum.com/forum/lighting-electrical-52/audi-bmw-side-marker-mod-61966/)
HcHawks09 Aug 9, 2011 08:51 PM
Thanks to KiwiBlazer for the support as I was inspired by him to take on this project.
Smoked Side Markers- $12.00 Ebay
Side Marker Pigtails- $10.00 Ebay
20 count of Cutting wheels- $6.00 Hardware Store
Black Foam Sheet- $1.00 Craft Store
Dremel, Wire, Connectors and Bulbs I already had.
First find a location for the side marker. I looked online for a template but came up empty handed. So I just eyeballed a location and made my own template out of cardboard.
http://i262.photobucket.com/albums/i...d/DSCN2298.jpg
Then tape the area you are going to be cutting.
http://i262.photobucket.com/albums/i...d/DSCN2297.jpg
Using the template, trace the oval onto the tape.
http://i262.photobucket.com/albums/i...d/DSCN2300.jpg
(now for the scary part!) DRILL your first hole into the fender. I drilled 4 in a row to eliminate the amount of cutting needed.
http://i262.photobucket.com/albums/i...d/DSCN2301.jpg
A steady hand is needed for the rest. Begin cutting with the dremel cutting wheel.
http://i262.photobucket.com/albums/i...d/DSCN2302.jpg
Remember, cut little at a time and test fit often.
http://i262.photobucket.com/albums/i...d/DSCN2303.jpghttp://i262.photobucket.com/albums/i...d/DSCN2304.jpghttp://i262.photobucket.com/albums/i...d/DSCN2305.jpg
Once cutting is complete use the grinding/sanding wheel to smooth the edges.
http://i262.photobucket.com/albums/i...d/DSCN2307.jpghttp://i262.photobucket.com/albums/i...d/DSCN2308.jpg
One last test fit and pray :D
http://i262.photobucket.com/albums/i...d/DSCN2313.jpg
Clean Cut :D
http://i262.photobucket.com/albums/i...d/DSCN2315.jpg
Time to wire it up. Attach leads to the pigtails (remember to measure and leave enough room for both headlight removal and side marker removal.
http://i262.photobucket.com/albums/i...d/DSCN2325.jpghttp://i262.photobucket.com/albums/i...d/DSCN2326.jpg
Tuck the wires away and splice them into a corner light, I chose the 97 bulb in the headlight housing.
http://i262.photobucket.com/albums/i...d/DSCN2327.jpg
Repeat for opposite side (flip template over) measure the finished side and double check your markings on the other side.
I found once installed that there was a little gap between the housing and body. I bought a sheet of black foam from the craft store, and cut a ring to fit around the light. Made it look finished and OEM.
http://i262.photobucket.com/albums/i...d/DSCN2329.jpghttp://i262.photobucket.com/albums/i...d/DSCN2331.jpg
Before:
http://i262.photobucket.com/albums/i...d/DSCN2332.jpg
After:
http://i262.photobucket.com/albums/i...d/DSCN2333.jpg
Installed:
http://i262.photobucket.com/albums/i...d/DSCN2317.jpg http://i262.photobucket.com/albums/i...d/DSCN2328.jpg
All lit up:
http://i262.photobucket.com/albums/i...DSCN2338-2.jpg
kiwiblazer Aug 10, 2011 01:25 AM
Looks good mate! Glad to help out.
That's what this forum is all about!
swartlkk Aug 10, 2011 07:14 AM
Looks good!:icon_razz:
HcHawks09 Aug 10, 2011 10:49 AM
Thanks Guys!!! :D I'm really happy with the way they turned out!
