Base model blazer with fused for powered options
Hey everyone,
I have a base model 2005 2dr blazer zr2. I want to put powered locks in with keyless entry. My fuse box is wired and fused for powerlocks and powered windows and in the door panels looks like there is a "junction box" where all the wires would connect into. Does anyone know if this is possible to just grab the wiring and actuator's and just plug them in from the junkyard. |
The harness in 2nd gens was a one for all so yes all you need is the parts you want and the missing wireharness. The plugs for it are somewhere and you might have to put a fuse in the block if its missing.
ok, so if I find one at the yard, I'd need to pick up the actuators, door wiring and would I need a module of some sorts also? Thanks!
I picked up the wiring and acutator from a '98 hoping it would just plug into my '05, but the plugs that plug into the harness are completely different.
| All times are GMT -5. The time now is 08:11 AM. |
