Battery cable removal question
While talking to the mgr. at the local AutoZone about some of my problems (looks like I need a new MAF Sensor) I was telling him about how I used to have to un-hook the cable from the batter because I could not remove the ignition key (got that fix). I told him I removed the positive cable and he said I should not have done that because I might have screwed a lot of things up, and I should the system re-set.
Anybody know what he is talking about, and did I really mess anything up? The battery was removed for an over night period. Many thanks in advance. |
Disconnecting the battery, whether it be the negative cable (which is the safest) or positive, will reset the system. If only done for a short period of time until repairs could be made, I doubt you did any real damage to your truck.
| All times are GMT -5. The time now is 06:25 AM. |
