brake pedal brake switch
I own a 1995 blazer 4 door 4.3 engine, so my tail lights don't work, I have checked bulbs and fuses and have replaced all, but still they don't work, so I bought a switch that goes above brake pedal I have 4 wires but there are 6 tabs on the new switch, any info on this could help. Thank you
Did you test the switch?
Well a buddy of mine did, while I was at work and he said I needed a new one so I went and bought one, but not to sure on how to install and adjust it, and where the wires go
On mine, a 2000, it just plugs into the connection. Plug and play I guess you could say. Have to say I'm surprised a '95 is hardwired.
Did you pull the connection and see if it would still plug into the switch? Just because there are 4 wires and 6 pins, it doesn't mean that the connector wouldn't go in properly. There may be contacts that don't get used in your particular application.
I have a 96, I have the same problems....no brake lights/hazard lights..going to check out that switch underneath the brake pedal. I hope that'll fix it
Originally Posted by chevyblazer1996
(Post 413365)
that's great, thanks for replying back, I'm going to find out where that is located tonight but if i can't find where it is, where do i find this multifunction switch for the hazards/brake lights?
The multifunction switch is located in the steering column. The hazard switch and the turn signal stalk are both part of the multifunction switch.
