Broken hazard button and now no break lights or turn signals
What do i do
If the hazard button is not reparable, then you'll likely need to replace the whole multi-function switch assembly. You can order them from most parts websites, or you could probably get a used one from a u-Pull type place. It's possible to do the job with common hand tools, and the procedure depends on what year and model vehicle you have.
Broadly you'll need to:
Hope this helps. |
(Post 755987)
Hope this helps. |
| All times are GMT -5. The time now is 06:26 AM. |
