Can your battery affect how the engine runs??
Old Oct 12, 2012 | 02:43 AM
GMC_Jimmy_13's Avatar
GMC_Jimmy_13 is on a distinguished road
Exclamation Can your battery affect how the engine runs??
A mechanic I took my corvette to told me the battery I had (a cheap everstart battery) was making the engine idle rough even though it starts it just fine? Reason I ask is because this is the battery I actually use in my Jimmy. Is it true a battery could affect the how the engine is running? Or it this dude full of $%@!
Old Oct 12, 2012 | 06:32 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Theoretically it COULD affect it, but I don't buy it without an explanation. Prove it to yourself; fire it up and unhook the battery. If the rough idle goes away then the mech is right, if it stays then its obviously another problem! Your battery just acts like a voltage buffer for the alternator when the engine is running. You could always hook a multi-meter to the battery while the engine is running and look for serious fluctuations. Compare those results to not running. What happens to the idle when you turn on your headlights or turn signals? If the engine stumbles then your battery may be on its last legs, but could also be your distributor contacts/plugs/wires are corroded.
Hope it Helps!
Old Oct 12, 2012 | 06:58 AM
richphotos's Avatar
I have personally not heard of this before. From my understanding, once the car is started, it runs off the alt. So I cant really see how the battery could effect how your car runs.
on a side note, Yay, Ugg boots.
Old Oct 12, 2012 | 08:45 AM
rriddle3's Avatar
Originally Posted by GMC_Jimmy_13
...Or it this dude full of $%@!
From my experience, yes he is. Once an engine is running, the battery is out of the loop since the power is being provided by the alternator.
Old Oct 12, 2012 | 09:22 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Arrow
Like everyone has said this guy is full of $^&*%.Now if your altenator is bad it wil.I have a voltage check on the Alenator.Clean off your battery connections and make sure they arent corroded.
Old Oct 12, 2012 | 01:10 PM
I'll try it out tonight and post what i find! thx
seriosbrad
Apr 3, 2014 03:46 AM
fnbutch
Jun 25, 2013 12:08 AM
bigdaddykane93
Sep 23, 2009 11:31 AM
bigdaddykane93
Sep 20, 2009 01:27 PM
SniperX13
Mar 12, 2006 08:49 PM
