Changing just two speakers?
I have a 2002 blazer LS with the cheaper sound system (Delco I think). I want to upgrade the sound system, but i dont want to spend a whole bunch. I found a headunit that came with two component speakers for under $150. If I change the stereo with a headunit and change the two component speakers in the front, then will it make my sound system better, or will the new speakers not sound good in conjunction with the old ones? This is assuming the new speakers sound better than the old ones.
Alton has said, and I have found true, rear speakers are of little use. Down the road you might use the rear channels to send signal to a woofer crossover I dont think that LS blazers have dash drivers but mine has factory wiring for a speaker. If you have true componants you will replace the bass blocker. Sometimes its just easier to run new wire to xo, tweet and mid.
mkm1387
Jan 22, 2014 09:56 PM
Stormedsoup
Mar 13, 2013 12:21 PM
stinz
Dec 28, 2012 06:44 AM
