Cruise Control Issues
Well Last night my cruise control just stoped working. Went to use it on the highway and nothing. Checked all the fuses and they are good, Disconnected the battery for about 5min and that didnt do anything. Any suggestions?
Check out these diagnostic steps (see attached).
DIAGNOSTIC AIDS
IMPORTANT: Perform the following in order to avoid misdiagnosis.
The vehicle speed is greater than 40 km/h (25 mph) Cruise Control Inoperative/Malfunctioning
- Inspect for proper operation of brake lamps.
- Inspect throttle linkage for mechanical binding which could cause the system to malfunction.
- Inspect cruise control cable adjustment, should have minimum slack.
- EMI on the speed sensor signal circuit may cause erratic cruise control operation.
Sorry to take so long to get back, But thanks to swartlkk's scmatics I was able to fix the problem. Turns out one of the wheel speed sensors wasnt plugged in all the way. Thanks for all your help!!!
982DRBlack
Jun 27, 2007 06:39 PM
6wraith
Jun 27, 2007 12:44 PM
