Cruise Control Issues
Old Sep 17, 2012 | 02:29 PM
1998blazerLS's Avatar
1998blazerLS is on a distinguished road
Default Cruise Control Issues
I have a 98, 4dr, 2wd, LS. My cruise control stops working at random. While driving on the interstate on a flat stretch with normal conditions (dry, music cranked, flat, straight, windows down) my cruise control will stop working. Even if I flip the switch back to "off" then to "on" and try to set it, nothing happens. After a while, I try it again, and it works. This started a couple months ago, and previously I could drive this same trip (I make the same trip every week, 2 hours long) and have no problem. Nothing has changed; I do the same thing every time I make the trip. Any suggestions on what the problem could be?
Old Sep 20, 2012 | 07:34 PM
Lgraham9291's Avatar
Lgraham9291 is on a distinguished road
It could be the multifunction switch which controls your cruise, blinkers, high beams, wipers etc. although all of the other electrical problems may not be broken (yet) it can happen slowly over time. The part itself is around 120$ so it's difficult to know for sure without being a wiring expert. I replaced it last night in my car to fix my high beams which were stuck in the high beam position even when flicked. There was nothing else affected by my slowly dying multifunction switch but I took the risk and it was worth it.
Old Sep 23, 2012 | 04:32 PM
I may have solved the problem, I had a stuck caliper on the rear passenger side. it just got a lot worse in the past week (so I finally noticed it). I fixed that this weekend, we'll see how that goes.
Old Sep 21, 2019 | 10:22 AM
Dan Fogg's Avatar
Dan Fogg is on a distinguished road
Please let me know if you were able to find the problem with your Cruise Control. I am having the same problem
Old Jan 8, 2023 | 03:24 PM
dylanvd93's Avatar
dylanvd93 is on a distinguished road
I believe I've found the issue. Same exact issue as this one.
https://blazerforum.com/forum/2nd-ge...w-beams-41857/
#4 pin on mine is burt as well
Esty
Feb 26, 2012 03:29 PM
darknight
Aug 21, 2011 12:17 PM
pj5454302
Nov 17, 2010 10:21 PM
yarinzim
May 9, 2010 07:58 PM
6wraith
Jun 27, 2007 12:44 PM
