Dash lights
I want to change the lights in my 2000 gmc jimmy dash behind my speedometer,oil pressure, voltage, temp, and fuel to blue lights. But I don't know what size/number the lights are. Also want to change the ones in the lock controls, light selector/fog light switch, and the ones in the radio. But like I said I dont know what bulbs/LEDs I need. Can someone help me with this?
Also are the ones in the 4 wheel drive selector change able?
I'd thought about doing the same but have not got around to it yet.... but as for the size bulbs you can check your manual or take off your dash and take a note of what bulbs are located where or just go online www.sylvania.com and choose your vehicle.
These bulb numbers for the rest should help you out.
Linky to bulby numbers for ya
Speaking of 4x4, I haven't checked into replacing the bulb for the manual shifter (for the 4x4) near the floor on mine with an led. I think it's replaceable? Do you know for sure Thogert?
All gm gauge lights are actually 162. Same base as a 194 but a bit dimmer. Most people put higher watt 194 in and in normal bulbs they burn hotter. Most places even list the replacement wrongly as 194. This is the reason you often see burnt plastic cause the higher wattage.
Dealing with leds go with the 194 and get a brighter bulb since heat isn't a factor.
In a first gen the floor shifter hold 4 or 5 and they are the same as the dash.
mrspeedy69
May 23, 2012 09:11 AM
new to chev
Apr 30, 2012 09:03 PM
Steeltoe623
Nov 12, 2011 03:10 PM
Aneurysm
13
May 3, 2008 12:27 AM
