-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Dash Lights don't work when headlights are on. (https://blazerforum.com/forum/lighting-electrical-52/dash-lights-dont-work-when-headlights-90060/)
AcidRelic Jun 15, 2015 07:53 PM
I have a 2002 Blazer and I just got it inspected for tags. One of the problems I need to fix are the dash lights. They work like normal except when the headlights are on then the dash lights go off. I'm thinking a relay maybe? Has anyone had this issue and how do I test and fix it.
Thanks.
El_Beautor Jun 16, 2015 10:13 AM
Have you checked your dash lights dimmer switch? That's where I'd start.
LeWhite Jun 16, 2015 11:26 AM
Might also check for a high resistance ground. Are your dome lights affected also. Or low capacity/weak battery.
AcidRelic Jun 16, 2015 01:30 PM
It's not the dimmer switch and no the dome light is not affected, New"ish" battery.
Thanks, keep the ideas coming.
LeWhite Jun 16, 2015 01:55 PM
The rheostat next to the headlight mode switch is 'open'. Day time running light relay fail.
