Disabling DRL's
Old Nov 3, 2011 | 10:05 PM
BigEffingHammer's Avatar
BigEffingHammer is on a distinguished road
Default Disabling DRL's
Hey guys, I've been trying to permanently disable the daytime running lights and it seems to not be working.
I've searched and searched and searched some more but with no luck...
I have a 2002 Blazer LS, with a fuse relay box under the hood, and a fuse panel on the driver's side of the dash.
On the fuse panel, there are no fuses labeled with DRL.
On the fuse relay box, there is a DRL relay, I pulled it out, DRL's still worked.
I bent over pins #85, #86, #87, without bending #87a or #30, and DRL's still worked.
If the DRL's still work, what did I just break by bending those pins? :O
Everything seems to be working as normal...
Old Nov 3, 2011 | 10:19 PM
gojorg's Avatar
That's odd, I pulled that relay off and got no drl's on mine but my automatic headlights work normally
Old Nov 3, 2011 | 10:23 PM
Wait, automatic headlights? ¿Què?
Old Nov 3, 2011 | 10:44 PM
gojorg's Avatar
the headlights come on automatically when is dark out
Old Nov 3, 2011 | 10:52 PM
In that case, how do you disable those? :O
Old Nov 3, 2011 | 10:58 PM
gojorg's Avatar
I read here on a post about it, it get's done with a resistor. My advice search disabling auto headlights and you should find it
https://blazerforum.com/forum/tech-a...disable-54549/
here it is
Last edited by swartlkk; Nov 4, 2011 at 07:04 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 3, 2011 | 11:06 PM
Thanks. Just found a link to essentially the same tutorial on S10 forum. I (in my ignorance) had thought that DRL's and auto headlights were the same thing.
Ironically, I bent the pins on the relay at about 10 at night, so the auto headlights came on.
Old Nov 3, 2011 | 11:12 PM
gojorg's Avatar
YW, you can turn the feature off by hitting the dome override button twice but it will come back on every time you start the truck
Old Nov 3, 2011 | 11:14 PM
Four times actually, and that's what I've been doing for the past few months. :P
Old Nov 3, 2011 | 11:43 PM
gojorg's Avatar
mine only takes 2
