door dinger?
Old Dec 11, 2012 | 11:37 PM
420Blazin4X4's Avatar
420Blazin4X4 is on a distinguished road
Default door dinger?
Can anyone tell me what fuse the door dinger is wired up to///Looked at owners manual and did a ton of online checking and came up SOL...would appreciate any help..Thanks..
Old Dec 12, 2012 | 02:22 AM
RetroBlazer's Avatar
RetroBlazer will become famous soon enough
Normally the Courtesy Lamp, but I think the chime is part of the radio in a 2003 so it's likely one of the radio fuses.
Old Dec 13, 2012 | 10:24 PM
Pretty much its my door dinger,my driver and passenger control lights and ashtray lights all stopped working at same time..I was changing stock bulbs to led`s and I put one in backwards..When I used a screw driver to loosen bulb to turn it around as led`s are polar it sparked and all the above has stopped working...Now Im stumped and fuming on this lol..
Old Dec 13, 2012 | 11:28 PM
xgiovannix12's Avatar
did you check your the fuse?
Old Dec 14, 2012 | 03:33 AM
fuses all appear intact... also couldnt pin point any specific fuse for the locations..
Old Dec 15, 2012 | 02:19 PM
Underhood fuses too?
Old Dec 17, 2012 | 04:18 PM
I checked under hood fuses..all look intact..pulled and checked each one..since I cant figure out which one it is even with owners manual..
Old Dec 17, 2012 | 04:26 PM
Twip's Avatar
are you trying to eliminate the door dinger or get it back? and all the lights still work?
Old Dec 17, 2012 | 04:31 PM
ok cool ty ..yeah that fuse is intact..off hand would you know what fuse operates the door control panel lights and ashtray by chance?
Old Dec 17, 2012 | 04:35 PM
I normally test a fuse with a multimeter .. I take the fuse and put the probes on each side.. If the meter rings the fuse is good..
your basically making a closed circuit that makes the meter tell you that you have a good connection.
