door dinger?
Can anyone tell me what fuse the door dinger is wired up to///Looked at owners manual and did a ton of online checking and came up SOL...would appreciate any help..Thanks..
Normally the Courtesy Lamp, but I think the chime is part of the radio in a 2003 so it's likely one of the radio fuses.
Pretty much its my door dinger,my driver and passenger control lights and ashtray lights all stopped working at same time..I was changing stock bulbs to led`s and I put one in backwards..When I used a screw driver to loosen bulb to turn it around as led`s are polar it sparked and all the above has stopped working...Now Im stumped and fuming on this lol..
did you check your the fuse?
fuses all appear intact... also couldnt pin point any specific fuse for the locations..
Underhood fuses too?
I checked under hood fuses..all look intact..pulled and checked each one..since I cant figure out which one it is even with owners manual..
are you trying to eliminate the door dinger or get it back? and all the lights still work?
ok cool ty ..yeah that fuse is intact..off hand would you know what fuse operates the door control panel lights and ashtray by chance?
I normally test a fuse with a multimeter .. I take the fuse and put the probes on each side.. If the meter rings the fuse is good..
your basically making a closed circuit that makes the meter tell you that you have a good connection. |
| All times are GMT -5. The time now is 02:48 AM. |
