Ebay Halo lights
Hey y'all OSS here;
Just picked up and installed some Ebay projector headlights + tailights today, and I'm wondering which wires I tap into to activate the Halo lights (I know it would be the DRL wires..which are they?) Also, the rear LED tail lights, which would be the DRL wires for these badboys? Thanks in advance y'all! -OSS |
Well the rears don't have or use DRL's. They're off in the daytime & on at night as they get hooked up in the regular fashion & are turned on with the AHL's.
As for the front halo's I got 3 way splice connectors & spliced into the low beam headlight wires. That way they're only on when the headlights/DRL's are on. This is for my '02 that has the DRL's as high beams on low power. So splice into which ever circuit your blazer uses as the DRL's or not - depending on your tastes. Have them on with the DRL's or only when the headlights are on with the AHL's. |
If the halos are leds they will not work correctly when you tap into the drl (high beams wired in series at 6 volts instead of 12) They are most likely CCFLs though, and I don't think the inverter will run on 6 volts either. I'd find a power source that is hot with the key on and either disable the stock drls or leave them as is.
As for the tail lights, you can run the halos with your parking lights or with the brake lights, which ever you decide. I think most use them with the parking lights, but some don't. |
