ecm1 fuse blows when ignition is turned on
Old Jul 26, 2012 | 06:10 AM
mcmastrman's Avatar
mcmastrman is on a distinguished road
Default ecm1 fuse blows when ignition is turned on
2001 Chevy Blazer 4wd 4dr
Truck died while driving. ecm1 Fuse is blown. replaced fuse, as soon as ignition is turned on fuse blows instantly. disconnected everything on the circuit, replaced fuse, plugged in comonents 1 by 1 turning on ingnition and checking fuse. fuse held strong until I plugged in the connector for the fuel ingection system (7 pink wires and 2 black wires going into plug located between the throtle body and the distributer cap).
I dont know where to go from here. ingnition switch, injectors, or wire shorting between the fuse block and the injector plug, or shorting wire beyond the plug? Not sure if the truck suddenly dying while driving is a clue. not an intermittent problem.
sombody please help me.
Brother Marc
Jul 5, 2013 09:39 PM
mcmastrman
Jul 26, 2012 06:27 PM
darkwarlord
Oct 20, 2010 10:48 AM
mrhockey4real
19
Aug 17, 2010 07:37 PM
leatherneck3112
Oct 4, 2009 10:28 AM
