electric fan wiring
Ok guys i see a lot of posts with ppl wanting to set up electric fans so after lots of reading heres what i came up with enjoy
http://i1309.photobucket.com/albums/...psepdnhp0j.jpghttps://blazerforum.com/forum/<a hre...psepdnhp0j.jpg |
If you have functioning A/C, you may want to set it up so that the fans turn on when the A/C compressor clutch engages to improve A/C efficiency at slow speeds. To accomplish this, you will need to wire in another relay.
Other than that note, looks good. |
Electric 2-speed fan wiring, ECM controlled
1 Attachment(s)
Here is another way of doing it. I used a two-speed Taurus fan.
The the e-fan option needs to be activated in the ECM for full functionality with temp settings of your choice. I used a JET DST #14005. A ground cable also needs to be pulled to pin #9 on the ECM black connector. This setup works perfectly. BosseT |
