Firewall Wire Routing
Old Aug 24, 2022 | 12:48 PM
Dayman's Avatar
Dayman is on a distinguished road
Default Firewall Wire Routing
I recently purchased a 2001 4x4 Blazer (W Vin) and had to replace the wire harness due to a check valve gone bad which burned a large section. While removing the old one I disconnected two wires, Purple w/ White Line and Gray, which did not appear to routed OEM to the harness. These two wires come through the firewall under what I assume is the cruise control box.
I checked the side of the wire harness going to the Fuse Relay Center box and identified a Purple wire w/ White Line going to one of these three fuses IGN B (50A), RAP (50A), IGN A (40A) . Currently the truck starts but has an incredibly weak idle and dies within about 60 seconds and I also cannot put the truck in gear.
I am hoping someone can help me with the correct way to route and connect this wire. The wire itself appears to be OEM based on color and condition.
The HOA is on my *** so thanks in advance,
Old Aug 24, 2022 | 02:41 PM
I thought purple and white was for the VSS, but I could be wrong.
Old Aug 24, 2022 | 02:43 PM
Dayman's Avatar
I followed the wire on my old harness and this is what I found.
fuse box - my thumb is on the location of the wire in question
fuse box - wire in question
ecu - wire is in terminal labeled 21
Old Aug 24, 2022 | 02:46 PM
Dayman's Avatar
wire connecting to O2 sensor
wire that was cut which is tapped into connector for the alternator i believe
Old Aug 24, 2022 | 02:47 PM
Dayman's Avatar
Do you know if its supposed to go through the firewall?
Apparently, there are multiple purple and white wires. I posted this diagram for somebody else yesterday. Maybe it will help you out, too.
File Type: pdf
Old Aug 24, 2022 | 02:49 PM
Dayman's Avatar
Do you know if its supposed to be routed through the firewall?
Old Aug 24, 2022 | 02:55 PM
Dayman's Avatar
Thanks incredibly helpful, thank you. After glancing at it it appears that is could be VSS or O2 sesor. Not sure if either of those are intended to go through the firewall. I could see O2 sensor being attritubted to my terrible idle but a vacuum leak could also be the culprit there
Old Aug 24, 2022 | 03:09 PM
I can't say for sure, but I wouldn't expect it to be.
Old Aug 25, 2022 | 11:14 AM
Dayman's Avatar
Im curous if its possible that this goes to the hood switch to control the light
