Flaser relay
Old Mar 29, 2013 | 02:23 PM
bryanbc's Avatar
bryanbc is on a distinguished road
Default Flaser relay
when ever i hit my brakes the flaser relay behind the glove box clicks nonstop till i let off the brakes and some times when im just cruising down the road.. ive replaced the relay but still does it. could it be the turn signal switch on the steering column that needs to be replaced?
Old Mar 29, 2013 | 03:51 PM
richphotos's Avatar
Kinda sounds like you have a short somewhere, when did this problem start? and when it started, did you do anything prior to the lighting, replace a bulb ect?
Old Mar 29, 2013 | 07:50 PM
bryanbc's Avatar
It was there when i bought the truck back in January but it didnt bug the crap out of me till recently and every thing works it just clicks nonstopp some times until i tap the brake or mess with the turn signal switch
Old Mar 29, 2013 | 11:20 PM
richphotos's Avatar
the multi function switch is expensive. Do you have any pull it yards around you? if you do, go to one, and grab a couple out of a couple blazers there, they are super cheap there, and try them, if the next one does the same thing, try another one, if that one does the same thing, then that is not the problem. and i would start digging around somewhere else.
I know it sounds like a lot of work, but I am trying to save you money. would rather have you spend a little money to find out if that is the problem, then to spend 100$ on a new multifunction switch to find out, that it was not the problem. then you just spent that money for no reason.
But with you messing with the turn signal switch, that is leading me to believe that it is indeed the multifunction switch (turn signal switch)
Old Mar 30, 2013 | 12:37 AM
xgiovannix12's Avatar
what are you driving? IF its the 1999 In your signature Wiggle the hazard switch when its clicking... see if that helps...
IF so you can buy a replacement hazard switch instead of changing the whole multifunction switch. Its way cheaper in the meantime.
Post back with your results when you wiggle the hazard switch.
Old Mar 30, 2013 | 10:20 AM
richphotos's Avatar
ahh touche!
Old Mar 31, 2013 | 07:59 PM
bryanbc's Avatar
When i wiggled it it made it go away and when i pulled it toward the passenger side it would click rapidly
Old Mar 31, 2013 | 08:05 PM
Ok I would pull the hazard switch and see how clean the contacts are inside and on the switch its self.
This is how you remove a broken hazard switch Broken Hazard Switch Repair How-to - Car Forums and Automotive Chat
If you get a really fine screw driver and pry the back forward a little It should release to little lock tab Gently pull the switch out.
Dont force it to much it will snap. If the switch needs to be replaced make sure you get an OEM one because the dorman ones are plain cheap quality and suck.
EDIT: Here is a picture to the little locking tab
its located on the back of the switch towards the cluster.
Old Mar 31, 2013 | 10:06 PM
bryanbc's Avatar
Alright thanks and yea im never buying a dorman product after the lower cooler lines i bought 1 month ago blew a hole in the hose part while on my home from work yesterday.
the hose they used was coolant hose which shouldnt be used for oil so im replacing the hose part with hydraulic hose tomorrow with clamps
Old Mar 31, 2013 | 10:24 PM
that sucks man Let me know how you make out with the flasher switch.
rastoma
Jan 10, 2010 06:55 AM
pj5454302
Dec 12, 2009 10:48 AM
bestes
May 31, 2008 03:16 PM
mytruck2
Dec 13, 2006 04:50 PM
sgarfield
Oct 11, 2005 05:13 PM
