-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Fuse box under the hood (https://blazerforum.com/forum/lighting-electrical-52/fuse-box-under-hood-68541/)
Black99blazer Mar 1, 2012 11:26 AM
I just got a 99 blazer lt and the fuse box under the hood has no power unless there is a wire goin straight to it from the battery. If you unhook the wire then you loose all power through out the truck. Could there be a short in a wires that connect to the bottom of the box? Any help is great thanx.
pettyfog Mar 1, 2012 11:56 AM
1 Attachment(s)
Yep, that is how it works. Where else would the fuseblock power come from?
If you have a problem, tell us. Are you saying it doesnt work without a kluge wire to the B+ stud on top? If so, look at diag, replace that big fuse.
Black99blazer Mar 1, 2012 01:12 PM
O ok thanx. I figured it had a power wire in the harness the connects To the bottom of the fuse box because it is a 6 gauge speaker wire that is ran in front of the radiator to the box.
