-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   gas gauge doesnt work (https://blazerforum.com/forum/lighting-electrical-52/gas-gauge-doesnt-work-85553/)
hoebob69 04-26-2014 09:13 PM
My gas gauge is stuck on full. It sat for over a year while I was working on it and I recently had to change the fuel pump because it wasn't sending enough pressure. I'm assuming its either the float,sending unit or the wires. Is there any tests I can do to better diagnose the problem?
abig84 04-29-2014 01:02 PM
check your grounds. is it way past full? that usually indicates a ground problem.
hoebob69 04-29-2014 07:12 PM
Mine is digital so it's a bar thing. But that sounds like a winner.
abig84 05-01-2014 12:52 PM
yeah not familiar with the digital gauge. but having owned a bunch of 80s s10s and k5 blazers over full was always the ground, if the gauge was just stuck and not moving it was the pink wire running inside the frame rail somewhere
hoebob69 05-01-2014 08:40 PM
Yea I know the harness on these are known to go bad and I thought there was a way to check those with out dropping the tank
abig84 05-02-2014 12:45 PM
the old fullsized trucks used to just corrode in the frame rail, you could just look at the wire and see it was all green and nasty. the grounds i believe are their own wire, like they bolt to the top of the tank and go to the body or frame. to test the sending unit you have to do a ohm test on it but i forget the exact details on how to do it, its been like 12 years since ive done one
