Gas and temp gauges
Hey guys. I have a 99 4dr. The gas and temperature gauges aren't working. The temp is as low as It will go. I've changed the coolant temp sensor an the thermostat. The gas gauge says empty and it says low fuel. And ideas?
gauges
I have the same issue plus others have you solved the problem yet?
| All times are GMT -5. The time now is 06:22 AM. |
