-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   gauges not working (https://blazerforum.com/forum/lighting-electrical-52/gauges-not-working-63825/)
rosie Oct 8, 2011 07:17 PM
gauges not working
I have a 1989 blazer with electric gauges. The fuel, temp and oil gauges are no longer lighting up when the car is turned on. I checked the fuses and they are all good. The speed gauge and turn signals are still lighting up however. what did you think?
xgiovannix12 Oct 8, 2011 07:24 PM
The cluster needs to be repaired most of our blazers have the same problem
I sent mine out and got it repaired and its good like new
the mileage stays the same since they send back the same cluster
I used this guy hes very good and fast
Chevrolet Blazer S10 GMC Jimmy Cluster Repair Service - eBay (item 330556241954 end time Oct-18-11 13:31:46 PDT)
also hes the cheapest i found
there is also a trading service where you buy a cluster for 125 bucks and then send yours back they refund you 100 bucks but the mileage wouldn't match your truck
http://cgi.ebay.com/ebaymotors/ELECT...item33671725f2
chris015 Oct 8, 2011 07:38 PM
yep,what he said^
The digital gauges are bad for going out,or a few not working etc.
xgiovannix12 Oct 8, 2011 07:40 PM
hi chris =)
rosie Oct 8, 2011 08:02 PM
thanks for the input. so this is something I can not do myself right, is it really expensive?
xgiovannix12 Oct 8, 2011 08:04 PM
the links above show how much it costs and if you dont know how to do it dont bother 1 mistake can cause more damage to the trucks system
rosie Oct 8, 2011 08:06 PM
thanks chris
chris015 Oct 8, 2011 08:10 PM
HI gio :)
rosie the main cause of the failure is a bad capacitor on the small power supply board. it goes out and the whole thing goes crazy. I found somewhere if u can solder good,you can replace that capacitor for like 2 bucks from radio shack and it may work. Il try to find the link for it.
edit :
I cant find the how to on it. Here is a link to what u can buy to fix it,and the how to.
http://cgi.ebay.com/ebaymotors/ws/eB...789+&viewitem=
See the big round capacitor on the left on the tan board? the smaller one under it drys up and goes bad,and causes the issues. I dont remember what type it is. If you are up to the task u can take your cluster apart and take it with you to radio shack etc and find the right one. or buy this
