headlight problems
I've been having problems with my passenger side regular light working sporadically. i took the headlight out of both just to compare and see if i could identify any problems. Now neither of the regular lights work. Highbeams are fine. Any ideas what the problem could be?
Sounds like a bad ground.
would it possibly be on the headlight wiring or on a switch inside the dashboard? where would you recommand me looking...?
What are you working on? :icon_shrug:
trying to fix my headlights. it used to be just my passenger side daytime running light. it would work sporadically. so i took my light covers off the check out the bulbs and possible replace. when i put them back on the lights worked for like 2miles then both shut off. i know i inserted them back correctly and snapped the wired correctly but i cant figure out whats worng now.when i go inside my truck the only lights that work are my brights. what should i do?
miami_canes, I think swartlkk was asking you the specifics of your vehicle. Year, model, that sort of thing.
oh sorry :icon_doh: ...its a 2001 blazer, 2wd, LT, v6..umm i think thats about it.
| All times are GMT -5. The time now is 09:30 AM. |
