headlight rewire...
hi,
i would like to rewire my headlights to make them brigther. i found a couple threads discuting it but i have a hard time traducting everyting in french... i want to start by doing to low-beams, and if i like the result, i will do the high-beams. now do i need 1 relay per side ?, or 1 relay for both low-beam ? if i undestand, 1 will work but if it fails, i will have no low-beams at all ? and i use the 2 stock wires that goes to the bulb on the relay, but what about on the driver side ? do i just tape them and leave them disconnected inside the wire loom ? thanks for any help ! Anthony |
anyone ?
Hopefully your screen name relates to your vehicle... Regardless, you should post your vehicle information.
As far as making your headlights brighter by adding relays, all 98+ trucks already have relays under the hood for the headlights. One relay or two just depends on how complicated you want to make it. If a single relay goes, you can always pull over and swap the wiring back around to stock provided you do a plug-n-play type installation by getting the proper mating plugs. |
thanks for the reply,
i have a 98 blazer 4door 4x4 auto. i know/guess that there is allready relays for the headlights but check this link: Headlight Rewire How-To 98+ - S-10 Forum it looks to improve lighting quite a lot ! the way they explain it/the way i will do it will not be plug and play.(if it fails during night i gotta have a back-up plan or a relay on each lights) if you have any tips for me let me know ! thank you |
| All times are GMT -5. The time now is 10:15 AM. |
