Originally Posted by Brandon90
(Post 718299)
I have a 2000 and a 2002. They both have automatic daytime running lights that are always on with the key. There are no special instructions on mine really. Anytime the key is on headlights are on, dohme light over ride button is located on the headlight switch. Push it several times and headlights go out. I have had 95 blazer, 96 s10 pickup and 98 pickup but didnt know of this method then, so I would push the park brake down just a hair to cut the lights off but not nearly enough for the brake to drag and never had a problem.
Do people think it could be because my Blazer was originally made for Canada?* Perhaps for them at the time, the ability to disable the DRLs and auto-headlights was disabled? _________ * I think it was intended for Canada because the Computer Climate Control was in Celsius and on the RPO decode, but not when I got it 10 years ago, it has a speedometer listed to be in kilometers. |
Just a thought, does your override button work for turning your dohme light off when your door is open? If not, maybe that part of your headlight switch is bad. I had to change my headlight switch the other day, everything worked except dash lights.
(Post 718299)
(Post 718307)
Post what you figure out if you dont mind, I'd be curious to know how it works myself. The more I think about it, a button that shuts off an entirely different circuit by switching on and off a few times seems a little odd lol
(Post 718313)
I still might play with the how I used the dome override button but I guess I'm stuck rigging my own override circuit. It has definitely become a personal challenge now! LOL P.S. I just now looked at the Wikipedia article on DRLs. Canada made DRLs mandatory starting in about 1990. To reduce costs, GM started adding them to the US vehicles too starting in about 1995. DRLs have never been mandatory in the US although GM did try to get them to be mandatory in the late 2000s (the late "naughts"). So perhaps my BCM or its programming is different. P.P.S. I remembered I had the CarFax for my Blazer and sure enough, it was first sold and registered in Alberta and a year later it was imported to the US then put up for sale at a dealership in Seattle with mileage of about 16,900 miles. |
Never would've thought of all that. Great info. Wonder If theres a fuse or relay that only powers DRL and could be disabled
(Post 718307)
Yes the override works for the dome light from what I have read don't switch override trick doesn't work on a 1999 |
| All times are GMT -5. The time now is 10:15 AM. |
