Headlights aren't working.
Old Nov 21, 2014 | 01:01 AM
MillenniumBlazer's Avatar
MillenniumBlazer is on a distinguished road
Default Headlights aren't working.
Hello, I have a 2000 4 door lt, I'm having issues with the headlights and I already replaced the main switch hoping that it would fix the problem, but it didn't, the only way I can use my headlights is with the parking brake set slightly on while driving, if disengaged, they shut off AGAIN AND WHILE ENGAGED i HAVE NO DRIVING Lights, I would like to resolve this asap.
Thanks in advance.
Old Nov 21, 2014 | 04:15 AM
mfrjames's Avatar
mfrjames is on a distinguished road
check to see if there is a switch down there it may be faulty.
Old Nov 21, 2014 | 03:27 PM
A switch at the brake or where?
Old Nov 21, 2014 | 04:10 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
if i had to guess, could it maybe be a faulty automatic headlight sensor located either in your defroster vent or passenger speaker grille. do you have normal headlights (halogen), or aftermarket like HIDs
do your Daytime Running Lights come on? when the vehicle isnt in park they should come on
Old Nov 21, 2014 | 06:06 PM
I have HIDs, and bypassed the auto lights sensor, its strictly turned on by the main switch.
Old Nov 21, 2014 | 06:07 PM
ANd i have no daytime lights unless the brake is disabled.
Old Nov 21, 2014 | 07:08 PM
richphotos's Avatar
That is an issue your HID's are causing most likely. Try un-hooking them and putting in halogens to see if the problem is corrected.
Old Nov 21, 2014 | 07:09 PM
Okay will try that and I'll be let you know if the problem persists.
Old Nov 22, 2014 | 12:05 AM
Alright so I went and got some basic halogen and the only difference they made are they look terrible haha
Old Nov 22, 2014 | 06:47 AM
rockinrandy's Avatar
rockinrandy is on a distinguished road
Check all your grounds and look for any toasty wires. Then start checking for power. Check the switch first then start tracing to the headlights from there.
