-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   Headlights low beam problem (https://blazerforum.com/forum/lighting-electrical-52/headlights-low-beam-problem-54064/)
dkatz Jan 14, 2011 08:41 AM
My headlight low beam stopped working some time ago. when i use the stalk to switch on the High beam they come on. I've tested the the high beams with a volt meter ant they show 13.4v. My low beams show nothing when switched on but show 30v !!! when the high beam is switched on. The lamps are all fine. I cant find a fuse or a relay. Please advise.
swartlkk Jan 14, 2011 08:53 AM
Vehicle info? Please include this basic information in EVERY request for help.
dkatz Jan 14, 2011 03:19 PM
My apologies
Its a 1995 Chevy Blazer 4WD
ChevyFamily Jan 27, 2011 12:38 PM
Got a similar problem with my 97, only the driver side low beam isn't working. Did you discover your problem. Was your problem on both sides?
bajabound Feb 20, 2011 07:47 PM
same here
1994 full size. have the high beams but no low beams. bulbs are good, replaced the switch, anyone with what to do next?
ChevyFamily Feb 21, 2011 11:37 AM
Mine ended up being the bulb after all. You check the relays? They are in the glove box on my model.
bajabound Feb 21, 2011 11:46 AM
Yeah, been in the glovebox too. I have to figure its in the stalk on the column as my wipers, washer and cruise are out as well. Is there a how-to here on diassembly of those?
swartlkk Mar 2, 2011 06:44 AM
Your truck really isn't a K5 blazer in the purest sense (SFA == K5 vs IFS =/= K5) and there are a lot of differences between your truck and the K5's (1st gen 69-72 & 2nd gen 73-91 vs 92+) in this regard. As such, there isn't a lot of information here about your truck. We can try to help, for sure, but please try to post up in the appropriate manner (i.e. not piggy backing off of a thread that is on a very different vehicle).
