-   Lighting & Electrical (https://blazerforum.com/forum/lighting-electrical-52/)
-   -   help aftermarket fuel gauge (https://blazerforum.com/forum/lighting-electrical-52/help-aftermarket-fuel-gauge-83245/)
xtrm4x4blzr1 12-09-2013 10:44 PM
Please help I need a fuel gauge lol. How do I wire an aftermarket in. Which wires do I use. I looked and looked on the forums and seem to can't find anything. Any one help me really quick like. My gauge is a power ground acc. Three prong.
richphotos 12-09-2013 10:46 PM
Is there a problem with your current gauge?
xtrm4x4blzr1 12-09-2013 11:05 PM
Yes the gas temp 4WD don't work. Had a short in the brown wire somewhere and I can't find it. I replaced all the brown wires in dash and under pass carpet looked under truck and still no luck. So this is were iI'm at.
xtrm4x4blzr1 12-10-2013 09:15 PM
Anyone have an idea? Do I just hook up power ground and I think the purple wire. Fuel level signal wire.
xtrm4x4blzr1 12-11-2013 06:58 PM
Wow ud think after 40+ views someone would have said its this wire and do this.
swartlkk 12-11-2013 07:08 PM
How to wire a fuel gauge - google.com :icon_doh:
Besides that, you might want to post up some actual information about your truck if you are looking for specific help.
If it is a 98+, there is always the fuel gauge diagnosis thread in the Tech Article (DIY) section which you have overlooked.
xtrm4x4blzr1 12-12-2013 11:20 AM
OK than smarty. 99 S10 blazer 4 door 4wd w/auto 4wd. About 300,000 miles. O its blue in color and 2 inch lift kit. Hope that helps with the info. And allI wanted to know is if u could just put a aftermarket fuel gauge causeI don't wanna trace all the wires cause its slowly dieing. And I did look at the diy sticky on fuel and ddidn't answer my questions. I know what's wrong and why I lost all my gauges (fuel temp 4wd and prnd21 )
